03.26.2008, 07:39 AM
Here is what the other leads look like. You can enlarge the pic for a better look.
http://www.amainhobbies.com/product_...ducts_id/12575
This is the 4s adapter for flightpower batteries.
http://www.flightpower.co.uk/Product...=FPVHR4S-VBALH
Now you will need an adapter to link the battery to the 4s adapter I listed above. It will have to have a male flightpower 4s plug on one end, and a female kokam 4s plug on the other end fo the battery to connect to. I do not know where to find that adapter, but either cheap battery packs.com or maxamps.com may be able to make you one. I could most likely make you the adapter, just need to find a female kokam 4s plug, and I have not found that yet.
I have a neuenergy 3s lipo and used this board with my lba charger:
http://www.maxamps.com/HYP-MULTI-KOKAM.htm
If you can find an adpater for the v balancer that will got to a 6s hyperiom tap, this board could be used.
