lutach
lutach's Avatar
03.26.2008, 04:38 PM
Here is what I had in mind. AWD braking. I've seen 1/5 and 1/4 scale use this, but mainly in the front wheel and a few do have them in all 4 and my idea will be inboard instead of them being at the wheel. I bought all the parts, but when came time to actually doing it, I was stuck with no time and skills to put it to work. It's easy and if I had the time I could actually do it. I even thought about going 4 discs in the front (Like a dual disc set up for each side) and 2 in the rear. I thought of using a similar set up like found in 1/5 scale, but also do something to utilize linkages to engage the brakes. I have attached a few pictures of the parts and the idea next to a diff case.
ID:	4304   Click image for larger version
ID:	4305   Click image for larger version
