03.28.2008, 01:21 AM
It's just annoying they aren't 5mm shaft and normal hole spacing.
True, but I removed the front endbell and drilled/tapped m3 holes in a 25mm spacing. You could have the shaft turned down, or drill out a pinion. I make my own mounts for these motors, so that is not a big deal for me. They are well worth the hassle, considering the price.
