xcntrk
xcntrk's Avatar
03.28.2008, 09:24 AM
Great info in this thread!
I’m attempting this conversion but have a few questions:
  1. Are the MGT spurs 32p or mod1 pitch? Are there any mod1 pitch spurs compatible with this slipper setup?
  2. For those who have closed the 10mm distance, between the motor and slipper plate, was it necessary to reposition the idler gear on the shaft (i.e. drill new hole, etc)? Or did you simply trim the rear of the shaft and shim the front to set the entire shaft back? (Gorilla tranny obviously)
  3. Is the new 3905 Emaxx input shaft the same as the Revo input shaft? Seems this upgrade “kit” from Traxxas is the easiest/cheapest way to gather all these parts (less spurs/pinions):
    http://www3.towerhobbies.com/cgi-bin...351x&search=Go
