Originally Posted by ren
I am thinking of trying the medusa 28-32-4200V2. They seem to be good (powerful) motors. You can gear up for higher top speeds, and use the lower gear for long runtimes. With the castle or quark esc.
You might only be able to fit a 16 or 17T pinion if you go with the 28mm diameter motors, but it should be fine.
