03.28.2008, 11:38 PM
Well I finally got my revo back together. Still using the steel dogbone center shafts and now I have a stock steel output shaft in the GMaxx tranny and lots of Loctite on everything!!! I did some running in the parking lot and I may need to change my gearing cause the esc seems to be getting pretty warm even with the temp outside being around 30f and the fan working on the esc. I guess I'll see how this works, wish me luck!
Gear ratio from input shaft to tire is 6.3:1
Spur/Pinion = 49/13 - 3.77:1
Total ratio = 23.75:1
Novak is looking for a 22:1 in a E-maxx, I'm close to a Lb lighter at 9.5 RTR
Reason: Added gear ratio
