03.29.2008, 11:33 AM
Yes the kyosho spur will fit the crt diff cup, you may need a paper gasket, as the crt might use an o-ring to seal with the current steel spur ear. Or you can use some sort of silicone or other glue to make a seal.
Just make sure that you lower the pinion tooth count to compensate for the smaller spur, but it looks like you have already figured that out!
