83gt
03.29.2008, 06:04 PM
Originally Posted by Sammus View Post
I think 80A wouldn't be enough to get it moving initially. Maybe if you were using the tekno clutch it would, but a big truck requires a bit of energy to get moving, and I suspect that spikes would be well over 100A if you floor it from a stand still. for 8000mah batts I would want at least 15C, preferably 20C. I think youll be able to get 35 out of it with that setup OK. I'm pretty sure I've seen some builds with nearly that exact combo, may want to have a look for them or something because this is all speculation for me now :)
Myself and several others are having good experience with the 8000mAh TrueRC packs. Although they are only rated at 10s, it seems they can do much better. They are a whole world better than the 20/30c maxamps 5000's I was running, all else the same. Somewhere around half the cost too :).
J.
