bluonyx
03.30.2008, 02:44 AM
The Hyperion Long Can YC22L features a 2.3mm shaft & a choice between 3900, 4400 & 5000Kv making it perfect for the Duratrax Mini-Quake & Vendetta and other vehicles requiring a 2.3mm shaft for its gear set and for those wishing to run on 6-10nimh cells or 2-3 cell li-poly packs. (we reccomend the 3900 & 4400 for 3 cell li-poly/8-10cell nimh & the 5000 for 2-3 cell li-poly/6-8cell nimh). The YC22L & Mamba 25 combo comes with stainless steel hardware and 3.5mm gold plugs ready to be installed. It also comes with adhesive filmed metal tape to be used on the back of the motor to block the rear vent holes for use in dirt/sand
http://b-p-p.com/proddetail.php?prod=de_YC22L
I just got the Hyperion YC22L for my quake and it's awesome, way better than the 4200 and 5400 mamba. It cogged constantly. Believe me, I tried both and wasted my money. I should have checked with BPP first. They're recommended setup were perfect. I'm running it with a 16T 2.3mm pinion and heatsink from TheToyz.com
