Thread: Lipo age
jhautz
jhautz's Avatar
03.30.2008, 05:21 PM
I'm with you linc... I have had one set of MaxAmps and they were no where near as good as the Enerland based packs. As a Matter of fact I feel like my 10C and 15C TrueRC packs were better than the Max Amps I had. The best thing about MaxAmps is their marketing.
If you want cheap the Zippy 5000mah 20C packs on UnitedHobbies.com are holding up decent for me. As good as the Max Amps and way cheaper. If not go with one of the other packs recomended by others above..
EDIT: With regard to your first question... I wouldnt mix. If one stronger than the other you will over discharge the weaker pack and ruin it. You are better off with a matched set purchased at the same time.
to make it...
or break it...
Silent...But Deadly
