03.30.2008, 11:26 PM
Originally Posted by Revracer View Post
really? isnt it good for like 80amps or so? i know the 85 is good for 125amps. thought i read somewhere that the 60 is good for around 80. the mega only takes 60
Rated qmp draw on motors is usually based on prop data. We use tires, and they can load a motor alot more, especially a full throttle during a standstill. The MM is car designed and does the job well. Plus 4s in a revo can pull 2hp sometimes, so 1hp=746watts. x2 is around 1500 watts. watts = voltsxamps, so 1500/14.8v=100amps or so. I usually buy my 4s packs with at least a 125amps cont. With 5s you can go down to 100amps cont.
We all know how well the mm works, plus it has reverse, so it is more versatile. I have even used one in a boat!
