03.30.2008, 11:31 PM
Have you owned a ls10? If not your argument is not valid. I have both. The .5 with the rcm ext chassis is a better racer. The center diff helps turning, and the chassis setup is better. The ls10 is much stronger, and has a plastic mod 1 spur with a slipper. It is a great basher, and much better to jump. I have not broken anything on mine, and it was used when I got it. I prefer the .5, but it is not as strong.
Can't wait till the mini hyper st comes out. I have a feeling that it will be much better than the .5.
