ChriZtoffer
03.31.2008, 02:09 PM
I had the exact same problem with my rear driveshaft on my G3R! But i managed to cut a bit off from the shaft on the rear differential, then i could slide the outdrive on to it long enough to fit the GorillaMaxx driveshaft. :) I hope that helps.
