03.31.2008, 06:18 PM
Brain thinking... I presume you are actaully running 2 x 5s packs - in which case the above won't actually help balancing across two packs as you'll just get two balanced packs but with different volatges ie. maybe 5 cells at 4.1 in pack 1 and 5 cells and 4.2 in pack 2...
I guess the network cable in the LBA10 config is feeding a cell voltage to the other lba10 so that they are in sync in terms of target voltage.
I don't know that this would actually get much difference if you balance charge each pack separately. Do you get that much deviation from 4.2?
