03.31.2008, 07:12 PM
The X-braces were 'hollowed out' on the G2 if you look at them from underneath, where-as the G3 braces are solid with no milling-out done to save weight = stronger but heavier. The upper plates & lower battery plate are also thicker- 3mm vs 2mm on the older chassis.
