Originally Posted by BrianG
Looks good! Except for the fan. Pull that baby apart, remove the fan, and replace the heatsink with one slightly larger and I'll be happy.
It actually has a pretty big cross cut heat sink already. The fan doesn't do much until you start really slamming it (like full throttle, full brake, full throttle, etc...) because it stays pretty cool most of the time.
Phase-Phase resistance is .000216 ohms. 67 mils of copper thickness on the circuit board. 6.5mm plugs with 10ga wires -- male plugs are included (and in the first run of production, we may be soldering the 10ga wires to the board... I don't know if we will have quantity of the solder-down bullets in time for the first production run.)
Patrick del Castillo
President
FIRST POST! YEAH!
