03.31.2008, 09:57 PM
I don't think your entire system should be running that hot. I'm not familiar with E-Maxx gearing, so I don't know if you're geared ok or not. Have you checked your drivetrain to make sure it's not binding somewhere? That would cause the current draw to be much higher than normal, which would heat things up. Also, what is your runtime on one pack?
