speedracer1129
04.02.2008, 11:45 AM
Actually, your amperage might go up a little with higher capacity packs since the voltage won't drop as much under load. But as long as the total pack Ah capacity X the C rating is greater than your current draw, you should be ok. If the pack voltage is still dropping below the 3v/cell LVC threshold, then I would say that the pack(s) aren't fulfilling their advertised specs.
That they are!! I had measured a 4.5v drop under load!! Logged in at 16v, max drop was 11.5v!! I spoke to FP about it and they told me the packs were wrong for the application. However, they told me that if I doubled the packs, it should have helped to further confirm that, but it is still doing the same!! This project has been very frustrating!!!!
