JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
04.02.2008, 12:40 PM
Hey Jerry, did you happen to buy that rustler from a crazy guy at a body shop in Slidell? That was me, I am that crazy guy! Glad that you have had more luck than I did.
Yep, that's the nut.
All I can think is that the velineon system is very power hungry, and does not like weak batteries. I was using a maxamps pack, 3s 4000, and we all know how well maxamps packs do with high power stuff (makes farty noise with mouth). It worked fine in my pede with the mm and the 12s feigao. And the performance was better with the mm/feigao combo. All I can think is that I may have found the sweat spot with that setup. I did not test the velineon that much, as I really did not care for it, and figured that it would sell better before I thrashed for testing purposes. I have a vxl pede now, but it has a sidewinder/aveox combo.
I guess it's all in the eye of the beholder. I prefer the VXL system for the most part because I still use the stock radios (for now anyway) and I don't get very good range at all from my MM RCs. As far as all the settings on the MM most of the time when I end up playing with them I end up mimicking the VXL. The only way you can really tell which ESC is in the RC is listen for the beep every 20 seconds or see if it goes more than 2 house lengths without going out of range.
