lutach
lutach's Avatar
04.03.2008, 03:57 AM
Originally Posted by BashOn View Post
My trans isn't locked so the motor brake won't work.
Is this something I could test just by seeing what the motor does when I use the motor brake? For example are you wanting me to see if it goes into reverse when I hit the brake?
The issue that I have when my controller is set for forward/brake only is when I apply the brake instead of braking it throttles up. The more throttle I give the stronger the throttle up is when I try to apply the brakes. It does this as well when forward/brake/reverse parameters are programmed too. I don't want you to break anything though.
