Desmo
04.03.2008, 08:36 PM
The issue that I have when my controller is set for forward/brake only is when I apply the brake instead of braking it throttles up. The more throttle I give the stronger the throttle up is when I try to apply the brakes. It does this as well when forward/brake/reverse parameters are programmed too. I don't want you to break anything though.
what does it do when you apply forward?
