Countryhick
04.05.2008, 03:47 AM
Originally Posted by potreinas View Post
I have some news to you and all mgm users that have this issue, it accelerates when you try to brake, mine only did this in4 or more poles like neu or align 600xl...
This is my story:
- Problem 1: First I had a 12018 (3.14) that does glitch all the time (instant braking while accelerating or brake all the time).
- Solution 1: MGM changed it for a 9032 (3.21) (paying the difference :) )
second part:
- Problem 2: the new 9032 accelerates while I'm trying to brake, but as you know only with 4 or more pole motors, with feigaos the esc worked perfect.
- Solution 2: sended the 9032 with a align 600xl motor to MGM to show them the issues.
Today I have receibed my REPAIRED MGM 9032 (3.22), MGM told me by e-mail:
"Problem was in defective processor. Rare case"
so... its not the problem of radio, receiver, battery, connectors, motor, etc... it was a defective component of the esc, so...
lutach, you have to send it to them, tell them my case, because it seems to be the same problem. This esc seems to work ok, it brakes PERFECT with the align 600xl motor, feigao, and neu motors :) this is 3.22 firmware.
If you have any question let me know and I'll asq you.
This weekend I'll test it to see if it's perfect or don't work perfect.
I just tested mine and I too was getting a surge when I went from throttle to brake. I then did the "AUTOTUNE" procedure and the problem went away. I then used my USB_Com and hit the default button to see if the problem came back, it didn't. I then tried a few different settings etc. to try and reproduce the "surge when braking" and couldn't reproduce it....
Not saying doing the "AUTOTUNE" will fix everyones problems but it maybe something for people to try before they send off their controls.
Cheers Andrew
