potreinas
04.05.2008, 04:54 AM
Originally Posted by Countryhick View Post
I just tested mine and I too was getting a surge when I went from throttle to brake. I then did the "AUTOTUNE" procedure and the problem went away. I then used my USB_Com and hit the default button to see if the problem came back, it didn't. I then tried a few different settings etc. to try and reproduce the "surge when braking" and couldn't reproduce it....
Not saying doing the "AUTOTUNE" will fix everyones problems but it maybe something for people to try before they send off their controls.
Cheers Andrew
I did it (autotune), but didn't work ok, I did all the test you can imagine and doesn't work.
My issue was a deffective processor, not the firmware, I suppose they upgraded my esc to have the latest software, but tue "accelerate while braking" seems to be a hardware problem.
All people that has this problems contact with mgm, and do all the tests that they tell you, they finally find a solution, (with me was about 3 escs and 3 months off nightmares) BUT FINALLY...
all the tests I have done with 2, 4, 6 and also 12 pole motors are OK, the accelerating while braking issue has dessapeared. the esc arm ok all the times (before I had to power on, off, and on to make it work :( )
and.... Countryhick... don't send the esc to mgm if you can do some tests, it's fustrating to not have the esc at home and don't know when will be at home and if it will work ok or not.
Today I'll test my mgm 9032 in my crt with 10s a123 :)
I'll let you know.
and.. sorry about my bad english
