Superbasher
Superbasher's Avatar
04.05.2008, 02:08 PM
Originally Posted by azjc View Post
its not so much wanting to drive fast, but wanting to upgrade to better components, the first time I took out the Rustler VXL one of the leads becames disconnected from the ESC and as I was troubleshooting to what the problem was, I soon discovered what I was dealing with....Traxxas products are good to get your feet wet with, that is there target audience.
I've had the same problem. I don't think it is a fault with the ESC, but more of a fault of where they put it, as the wires stick up further than the shock tower, meaning that if you land a jump upside down they break, which mine did. I managed to fix it by soldering the connector back on the PCB, but i'm on the hunt for a cheap MM ESC.
  Send a message via MSN to Superbasher
