Buzzsaw46
04.05.2008, 07:33 PM
It was three days maybe four. Very quick really.
Just got done with the first run with it! 9 min and the temp was under 100f. I did eagle tree it but the ET temp loop slipped off and all I had for temps was an MIP onboard.
I was running a 13t/68t gear set and it seems a bit lower power overall than the Ammo with the same gears.
Here is the amp/volt data for the Medusa.
Ammo data graph.
Dang I'll need to redo the Ammo data I seem to have started on less than a full charge that run. I also had the ET set for a two pole motor so my RPM reading are goofed for the medusa run.
