Buzzsaw46
04.05.2008, 09:16 PM
Just came in for another run this time on 14t pinion.
The puases are me checking the onboard temp guage I repositioned it and cant see it through the body now. The temp climed to 114.7 after I powered down. ESC temps peaked at around 140f
Power felt more on par with the Ammo this run, and its obvious the motor has more to give. Too dark to continue today.
Was catching some big air with it tonight. Cleared the two lane gravel road by a good 5' so I'm luanching it a good 30' long and 8-9' high, Awesome!!!
Forgot to mention the Prop RPM is wheel speed and I'm running Mulcher tires with molded foams so there is very little tire ballooning.
