azjc
04.05.2008, 11:00 PM
Originally Posted by Superbasher View Post
I've had the same problem. I don't think it is a fault with the ESC, but more of a fault of where they put it, as the wires stick up further than the shock tower, meaning that if you land a jump upside down they break, which mine did. I managed to fix it by soldering the connector back on the PCB, but i'm on the hunt for a cheap MM ESC.
I agree with you that the location of the ESC is bad, I have since located my MM and BEC on the lower chassis opposite of the RX using velco to secure
