04.06.2008, 03:01 AM
You may want to turn the start power up with the medusa, and disable the punch control. I usually leave the timing to normal, as higher timing seems to cause extra heat. It does make more power with higher timing, but I am not usually looking for more power! Just trying to smooth out the power from a standstill,
Graphs look good, thanks for the info. I have a 1500kv 60mm medusa coming, and plan to run it in my hyper8 buggy on 6s lipo.
