Electric Dave
04.06.2008, 03:10 PM
The Finned versions are larger (diameter) and weigh a bit more. I'd like to know if the heat reduction is worth more than the larger size/weight.
I realize no one is likely able to give us real numbers but how about an idea? Does the finned version stay 2 degrees cooler or 20 degrees? Is it likely to be a big number or a small number?
DM
