09.11.2005, 01:55 PM
I raced my Revo with the latest center diff solution and put it to the test. It worked well during practice and through the first heat. For the second heat, I geared the truck up a touch, for more top speed, and the center diff plate failed :eek:
Well, back to the drawing board. I need to make this plate bulletproof for this BL powerplant so I'm going to use a thicker diff plate and figure out how to ensure the screws for the gear do not come loose. Other than a little melted plastic on the tranny case it worked well. This can be corrected with proper spacers.
I'll report back when this is fixed
Ha Ha
