TexasSP
Something, anything, nothing
TexasSP's Avatar
04.08.2008, 12:47 PM
The right body, body scissors, a knife, and a heat gun and you could rig up some good down force. I did this with my stock pede body and eliminated a lot of lift. You also want to be concerned about the rear at the same time because rear lift can cause the front to get squirrely and lift as well. If you are using a truck body, simply cutting out the tailgate section does wonders. Sometimes it just takes experimenting with different things.
www.cubicle101.com
