04.08.2008, 02:58 PM
I would also think about upgrade plans. Most balancers are capable of up to 6s, but if you get a 7s+ pack, you won't be able to use it.
The LBA10 is rated for 6s, but does allow you to network another LBA10 for up to 12s balancing. You would have to also make Y adaptors though when networking two of them.
The Thunderpower TP210 allows you to balance up to 10s.
No matter which balancer you get, you can make adaptor leads (or use an adaptor already available) to make the taps from different manufactures work with it.
