skellyo
skellyo's Avatar
04.08.2008, 10:53 PM
Originally Posted by wade7575 View Post
Novak told me they were getting to many people bending the stock 1/8 shaft on the rotor with the E-MAXX that why decided to upgrade.So my problem is that there saying to run a 12 pinion when running 16.8 volts but you can go bigger but in grass it maybe to much for the 6.5 setup to handle.If I can not get 5MM bore pinions in 32 pitch that are 12 tooth I will try sticking with the stock rotor and see if it bends.Also does anyone know if Mike at rc-monster has a phone number I can reach him at.Thanks for the help guys.
A lot folks were bugging them for a 5mm shaft to use in 1/8th scale conversions...not to use in E-Maxxes. However, I'm sure some folks have had problems with them in E-Maxxes, but part of that could be from folks running the slipper tightened all the way.
But, look at it this way. Without spending the money to upgrade to the 5mm shaft from the get go, all it costs you is a $4 pinion. If you break the stock rotor shaft, no real harm done since you can just buy the 5mm upgrade anyhow.
