dduaime
04.09.2008, 12:36 PM
Originally Posted by bl-is-future View Post
I have had no problems with drive train. Make sure your diffs are shimmed correctly. That is the main reason they fall apart. If you shim them properly you should be fine.
I locked the slipper and made the start power of the Mamba at 50% (still plenty to make it wheely though.)
The Neu will give more torque because it can handle more volts for it is rated at 60000 RPM as apposed to 40000 RPM and because of the voltage increase it should result in in more torque and a little better top end because of the higher RPM capability.
The 8xl setup should outperform the picco .28 and the 1521 definitely will.
You have 4s on MambaMax? It's rated for 3s max???
Thanks a lot for your info!!
