glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.11.2008, 10:32 PM
lincpimp... I hope you are not using this maxamps pack as a test pack?
It's not likely that the remaining cells are in 100% condition.
Also, the bottom cell in the pic above actually looks like it might be slightly puffed. A good cell is completely flat... no curve to it.
One of those cells has to be swelled...
I had a pack that had a very slight puff to it... barely noticeable. It lasted a long time like that but eventually did get worse and puffed more. That was a pack that got taken out with an ESC meltdown.
I think the non-copper tab is tin, not aluminum...? Alum is very soft and requires special flux to solder.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
