aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.12.2008, 09:21 AM
Peter, are you positive?.. because LMT said the Hi-Amps were different and was able to deliver more power than the regular 2280s, the stators and rotor are different as well... http://www.lehner-motoren.com/motordaten/Motordaten%202280/2280-5.HA32V.xls
Those datas from LMT were the only reason I purchased this motor back then... because back then, I knew that they will finally have something like the 40.300 out...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
