aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.12.2008, 09:53 AM
I would recommend you use/get..
Bulldog 30Amp Power supply
2x 4S/5S 25C/30C 5000mAh/6000mAh Lipos
Hyperion EOS 610i DUO .. charge both packs at the same time, up to 6s.. maximum of 360 Watts!!!
right now, you're only limited by ur ESC.. can only pump out 97 Amps...
even better, you could just stick to 3700mah 25/30C lipos.. save even some more weight....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
