sikeston34m
sikeston34m's Avatar
04.12.2008, 11:53 AM
Originally Posted by DwightSchrute View Post
thanks...i think i might be geared too high as i'm hitting about 1850 watts when i should be at around 1400...i might need to also set the factory defaults back instead of having zero punch control and the timing turned all the way up...etc...i had everything set for the absolutest worst place to help cooling.
Also, would you recommend the HV capacitor? what exactly does it do?
The Added Capacitor helps to smooth things out in the powerline.
There are several added advantages that it gives your setup. Without going into a lot of technical detail, it can help your ESC run 15 degrees or more cooler.
If you want more information on what it does, there are numerous threads here that discuss this topic. Be warned, it gets deep! LOL
Sounds like you might indeed be over geared. Try setting the timing on the lowest setting and give it some punch control. (50% or so). This will help tame those huge current spikes on startup.
