RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.12.2008, 04:08 PM
Mine is different than Dan's - for starters, it is built to accept the factory mechanical brake setup - just like the motor mount itself. It also has 4 fan hole cutouts vs. Dan's 3, has threaded holes to attach a 30mm fan, and follows similar lines to the stock part it replaces(Dan's is an "x" pattern over the diff). I can't see Dan being too upset - after all, I was making the motor mounts long before he was. :)
By the way...it has RC-Monster engraved on it 2 times if you look close(over the diff). :)
