glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.12.2008, 11:11 PM
Mine is different than Dan's - for starters, it is built to accept the factory mechanical brake setup - just like the motor mount itself. It also has 4 fan hole cutouts vs. Dan's 3, has threaded holes to attach a 30mm fan, and follows similar lines to the stock part it replaces(Dan's is an "x" pattern over the diff). I can't see Dan being too upset - after all, I was making the motor mounts long before he was. :)
By the way...it has RC-Monster engraved on it 2 times if you look close(over the diff). :)
No kidding... that's why I found it amusing that guys were talking about RCPD getting patents on his products!
This was my initial reaction to that idea: then:
Shouldn't even consider putting a patent on something you didn't do first, whether it's legal or not.
To give them some credit, I think they had in mind mostly the machined battery tray/mudguard. But still...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
