supralover72
supralover72's Avatar
04.13.2008, 02:10 PM
@supralover72
What is the wheelbase of mike's CRT.5 chassis?
When looking at the dimensions of this truck i think a regular 1:8 buggy chassis would fit well under this body.
Wow, I didn't realize it was that long. With the ext. chassis, the crt.5 is 396mm long and when his ext arms come out, it should be the same width. It's 279mm wide now.
Still, you can't match the original, thunder tech CORR truck kit, with RPM arms, rock solid chassis, Lexan AND Hard plastic display body that you can repaint, tamiya high lift wheels and tires, and a whole lot more:
http://www.thundertechracing.com/pro2a.htm
