04.13.2008, 09:18 PM
Question, on your 3s run, was that with the 3s pack the entire time? Looking at the bottom of the graph it lists min voltage at 6.11v! Not sure if that is right.
The 2s pack shows a max draw of 105 amps, and a low voltage of 6.01v. If that is correct, then the cells cannot keep voltage over 3.5v at their rated constant.
