04.15.2008, 12:11 AM
Originally Posted by entjoles View Post
i had 30k in the vid, i just changed it tonight to 10k when i changed my spur
for my motor i used loctite epoxy to reglue it to the shaft, it worked great and the motor still spins as it did before , but it may be part of the problem
You may not have the magnet glued to the shaft in the correct place. I would say to try another motor. Sounds like it is working the esc too hard.
