09.12.2005, 07:22 PM
actually it would me 14.8 volts and i think i would try a 12 tooth pinion because if im not mistaken the ue diffs have a different gear ratio than standard. the problem is probable to many rpms.
if this is the problem which i believe it is then it should be fine with a 12 tooth pinion. please correct me if im wrong.
