Cowboy
04.15.2008, 09:45 PM
This is what I'm using. It's very simple. It is just a ammeter and a voltmeter with adjustable load. You just hook your battery up to it and turn the knob. As amps go up volts go down, just watch the gauges. You can adjust it for any load you want. If you want to do a long test like 40 amps for 10 minutes I would put a fan on it
