04.16.2008, 11:42 AM
I wonder if you could do the same type of thing that is done in the Revo tranny to lock it? Basically, physically couple the centrifugal clutch to the second gear. This would be a true lock and thus would allow you to use motor braking and even reverse. And, depending on the design, you might be able to remove first gear and OWB to reduce some weight...
