04.17.2008, 01:46 AM
after all the upgrades (alum. cups, diff housings and bulkheads, 4 spiders shimmed) i found the weak link to be the pinion shaft bearings, they went and I ended up shearing diffs, I haven't had that problem since I ran bocas on the pinion, its the only place I use spendy bearings, but so far they've held up to the o.s. .30
