UH60sSuck
UH60sSuck's Avatar
04.18.2008, 08:04 AM
Mine runs about 45 with a 7xl and 4 cell 8000mah lipo. I would suggest using a 9xl cuz it doesnt run as hot. But what your going to need is a, unless you build on by youself, A conversion kit. I got one from techno. Your gunna need a ESC, external BEC, Motor, Battery, and soldering Iron. You might also want to order the robinson racing steal gear kit and depending on the tires you got you might wanna order some more. Also for you esc you should get a fan. I might be leaving something out but thats it for the most part.
