GriffinRU
04.18.2008, 01:53 PM
Originally Posted by cadima View Post
What is the point of these Zener diodes? What is there function, and exactly how do you solder these things to the board? Thx!
04.16.2008 07:24 PM
DrKnow65
I believe suicideniel is correct about the "clamp" function. I just soldered mine to the back side of the power board where the battery leads poke out.
04.16.2008 07:01 PM
I believe they are refered to as 'voltage clamps', and the purpose is to absorb transient voltage spikes that might harm the cap or batteries... something like that I think i read a while back...
They are surface mounted normally, so good soldering skills and a good iron are required.
- Just to add for the comments above
Zeners/Transorbs voltage was selected to protect FET's from voltage spikes, running at 4-5S close to FET's rated voltage and for caps. With temp going up caps rated voltage goes down as well over the time, so to keep them happy I installed zener.
And as bonus reverse polarity protection for FET's, not for wires and bad soldering :)
DO NOT CHECK it!
