Originally Posted by Gee
Man that is nice Shawn. Every time I go through your build I keep thinking I should of did that too. Looks like it going to be damn tough with the diffs you got. I used some lexan under the motor on my g3r also. I have the mm so it doesn't fit under the motor but it close to it. I cut a little part out and installed a small fan that blows up from the bottom. Needed it with the Novak but the Neu is running cool. So now it just a hole in the lexan with a fan. I'm on my second stock differential. I wish I would of got the diffs to begin with.......
I'm running 54/26 on my G3R Neu 1515 1/ w/ 4s same tranny but diff are stock. I haven't played much with the gearing once I put those on.
Hay Gee..
I’ve seen your build (it’s awesome!) inspired me to build mine.. (Don’t kid yourself)..
Thanks for the gearing suggestions..
FYI..
I just received my body a few minutes ago and I'm confirmed with Mike / Fast lane for the show tomorrow! :), I'm showing casing two of my builds there (dream come true)
of course I’ll be up all night getting them ready. &!!! my MGM controller came to life this morning
Good times ahead.. Good times..
It's always pleasure and have a great one Sir
Shaun.
